On right turn only blinker will go at a faster than normal rate, and will receive message of bad bulb. I have replaced all bulbs and problems still occurs. This is an intermit problem.
I have checked bulbs, and also checked the grounding to each socket.
When the four way flasher is used all works ok. Could this be a flasher problem and if so where would the flasher be loacted?
Sep 19, 2007 at 4:07 AM
