2006 Volvo V70 rear seat/sear belt
2006 VOLVO V70
37,000 MILES • 4 CYL • FWD • MANUAL
DAVID SAVAGE
When i fold down the rear seat the seat belt locks and i cannot raise the seat,
updated 12/21/09
Hi thanks for your reply and comment,it works, job sorted,many thanks and have a happy Christmas and new year
Dec 14, 2009 at 3:24 PM
JIS001
  • 3,412 POSTS
You will need to remove the bench to loosen up the seat belt bolt for the one that is hanging up. Once you get the seat up, pull the belt down and look at the other side seat belt. You should see a little buttonon it. If the one getting stuck is missing the button that i why your seat belt gets stuck. The button stops the belt from retracting too far so that the backrest does not get stuck down. You can get the seat belt button from Volvo. The old button should have left an indentation on the belt so use that as your guide. Good luck an hope this helps. Keep me posted please.
Dec 14, 2009 at 4:14 PM
