2005 Volvo V70 Stereo power
NOSYJASE
Electrical problem
2005 Volvo V70 Front Wheel Drive Manual 75000 miles
Hi, I have a 05 volvo v70 but the stereo has no power and also the cigar lighter aswell. I have checked the fuses and they are ok and I have checked the stereo and it works if i power it directly. Has any one got any ideas??
Thanks Jase
Oct 30, 2009 at 10:18 AM
JIS001
  • 3,412 POSTS
Where did you check the fuses at? When you open the drivers door on the side of the dash is a cover. Remove fuse #10 (20A) and #11 (30A) and inspect to see if they are ok. That is for the audio system. For the 12 volt sockets, remove the drivers side sound proof panel. 2 screws holding it and look right under there will be more fuses. Remove and inspect fuse #11 (15A) to see if it is ok. If you do not have your owners manuel I would encourage you to go to this website.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
You can register there and you can access the owners manuel to any Volvo from 1965 to the present. Hope this helps. If you need further assistance let me know.
Oct 31, 2009 at 5:05 AM
