2004 Volvo V70 message center
2004 VOLVO V70
LOEFFLERME
Electrical problem
2004 Volvo V70 Front Wheel Drive Automatic 74000 miles
how to clear the message center for regular service required and a message for the bulb position light is on message board but all lights seem to be functional
Feb 5, 2010 at 3:27 PM
JIS001
  • CAR REPAIR CONTRIBUTOR
  • 3,412 POSTS
Check all your position bulbs. You may have more then one out on. Check the fronts and the rear. Replace the burnt ones and the message will go away. As for the service light. Put key in position one. Hold the trip button in. While holding button turn the key to position 2 and keep holding button in. Once the orange triangle starts to flash, let go of the button and it should be reset. If it did not work, repeat the procedure. Sometimes I dont get it right the first time either LOL :)
Feb 7, 2010 at 4:49 PM
