2003 Volvo V70 master cylinder help
35,000 MILES • 4 CYL • 2WD • AUTOMATIC
GOORDDYS
my pedal is really soft, just change front and rear brake pads and rotors, bled lines, still is soft any ideas
Aug 14, 2009 at 2:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
was pedal soft prior to brake replacement? inspect brake fluid level. also ensure all brake hoses / lines are connected properly and free of any kinks or damage
Aug 14, 2009 at 2:23 PM
GOORDDYS
ya it was thought i would change rotors and pads, if i hold down brake pedal it slowly sinks to the floor
Aug 14, 2009 at 2:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check the vacuum hose to the brake booster to ensure it is not damaged. also try the steps below to test the brake booster out..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_830.jpg
if booster tests OK, suspect a faulty master cylinder
Aug 14, 2009 at 2:29 PM
