Interior problem
2002 Volvo V70 6 cyl Automatic 100000 miles
My grandmother has had issues with the steering wheel not coming out of the lock position. I thought she just didnt know what she was doing but I have major issues with it also. Last night it was bad and I tried for about 30 minutes wiggling the key and steering wheel so we could get the car started. The key wont budge. I took out the 3 screws out of the column plastic and remove the plastic. I then took a screw driver and released the cover that goes around the switch housing. I tapped on the unit 10 times with a screw driver hoping that something would come loose and it start working. Well, it did. I worked perfectly after that.
What could have caused this and what do you think needs to be replaced to prevent this from happening again.
Nov 7, 2010 at 5:06 AM
