2001 Volvo V70 take off shift knob
2001 VOLVO V70
MARIN4IK68
Interior problem
2001 Volvo V70 Front Wheel Drive Automatic 88,000 miles
Do you have any idea ho to take off the shift knob easily without going to the specialist. I just need to replace it because my is broken.
Sep 10, 2009 at 11:10 AM
JIS001
  • 3,412 POSTS
Put it in nuetral with the e-brake on. On the upper part of the boot feel for a snap ring. Twist and pull down on it. When you have done that hold the button in and pull up on the knob. This will not be easy and be carefull not to smack your face when it comes up. To install the new one I usually just grab a bundle of clean rags and put it over the knob and hit it with a rubber mallet. Then after reinstall the boot. Good luck and hope this helps.
Sep 11, 2009 at 12:29 AM
