2001 Volvo V70 obd codes
WILLSTON
Computer problem
2001 Volvo V70 Front Wheel Drive Automatic 92000 miles
Hey just wondering if you have any input on what would make it kick out the code 0422. The chart says main catalyst performing below threshold but do you have any more than that?
Dec 19, 2008 at 1:11 PM
DAVE H
  • 13,383 POSTS
I do not have a listing for PO422 .. the PO420 series codes deals with the cat ..
P0420/ECM-4201: THREE-WAY CATALYTIC CONVERTER EFFICIENCY
Fault Conditions
ECM controls three-way catalytic converter application after start up by changing between rich and lean fuel mixture. When change takes place the signal from rear heated oxygen sensor and the speed of change are checked. ECM-4201 is stored if ECM registers that rear heated oxygen sensor changes too quickly.
Possible Causes
Air leakage in exhaust system
Defective catalytic converter
Diagnostic Procedure (Power Deterioration)
Check for air leakage and check components. Check for air leakage from the exhaust system. Try a new three-way catalytic converter if no fault has been detected in the exhaust system.
Jan 8, 2009 at 11:32 PM
