2001 Volvo V70 Engine just started shaking badly
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
BORDER58
My wife was driving the car and was only a block away from the house when the engine started to shake,vibrate,loose power and about every warning light on the dash came on. I went out and started it and it idles although shaking badly and when I tried to rev it up it strains to get the rpm's up.
Oct 12, 2010 at 11:38 AM
BMRFIXIT
  • 19,053 POSTS
Is your check engine light on and or blinking
have to check for codes 1st
let me know what you have for codes
a blinking check engine light is an indication of a misfire
check coil if firing all cylinders
also check charging system
Oct 12, 2010 at 12:36 PM
