2001 Volvo V70 cool air drops in and out
125,000 MILES • 4 CYL • FWD • AUTOMATIC
OGLECARS
While running my air conditioner the cool air will run cool for awhile but then drops out, after awhile it will start to run cool again. Seems to be at its worse on really hot humid days. This has been going on for awhile and seems to be getting worse.
Sep 4, 2009 at 11:48 PM
DOCFIXIT
  • 18,828 POSTS
Is AC compressor cutting off? Has charge been checked?
Sep 5, 2009 at 7:42 AM
HOLLOWELL
I have found that these cars built during this time period are prone to having a clearance problem with the compressor clutch. With age and use and decreasing magnetic power the clutch, especially on hot days fails to engage when power is sent to the clutch. The hot weather can cause less power being able to travel to the clutch. The clutch can be serviced and the magnets adjusted closer together. I have found a very easy fix for this problem, especially if you are not familiar with working on these clutches.
If you can locate the two wires running to the clutch on the AC, locate a heavy duty relay at any parts store(usually beteen 10 and 20 dollars). If you cut one of the 2 wires running to the clutch and connect a runner from the car side of the cut to the switch terminal on the relay and use a runner from the + terminal of the battery(make sure you have a negative ground vehicle-in this case your car is) to the BAT lead on the relay. Use a runner from the clutch side of the cut wire to the Load terminal on the relay. Finally connect a runner from the Ground terminal on the relay to a good chassis ground. What this allows to happen is when the control unit sends power to the clutch to engade it, it now is intercepted by the relay which closes and sends power on to the clutch directly from the battery. When the clutch has cycled and the control unit cuts power to the relay(switch terminal) the relay opens and stops flow from the battery. Use a heavier guage wire, I use 10 guage. I have only had one unit that this method did not fix. A good canidate for this repair is a car that the cooling comes and goes. If the freon is low it generally would not cool at all. The hot weather puts a strain on the electrical system so it is a good idea to check the condition of the battery and alternator just to make sure you they are performing to specifications. This is much better than having to replace the clutch(cost wise) and I see a lot of customers who have been advised to replace the compressor assembly because of the failure to cool on regular cycles. You should be able to make this repair in about 30 minutes or less. Remember this is just an example of one type of repair. Without having the vehicle to diagnose in person this is just a suggestion based on seeing others performing in a similiar manner.
Sep 6, 2009 at 3:27 AM
OGLECARS
No, the AC compressor is not cutting off. Yes, the charge was checked and found to be slightly low and was recharged, this worked for a few days but then the weather cooled down at the same time. As soon as it got hot and humid it went back to its old tricks.
Additional information: The temp gage/light (right above the steering column) ranges from 6 or 8 degrees when it is totally not blowing any cool air to anywhere above 30 degrees when it will start to cool again. I was told that this light has nothing to do with the AC but it sure seems like it to me.
Sep 6, 2009 at 9:37 PM
DOCFIXIT
  • 18,828 POSTS
Can you get a guage set andd hook it up? if no try this put AC in recirculation mode set fan on low max cold windows and doors closed. Run AC observe compressor does it cycle off? put thermo in center vent what is vent temp?
Sep 7, 2009 at 5:56 AM
