2001 Volvo V70 01 V70 tail light wont work
108,000 MILES • 4 CYL • 2WD • AUTOMATIC
RYDAST
I have replaced the tail light several times, I have cleaned off the connections, I have even replaced the entire "plug" that holds the light with the one that works on the other side. This light will still not work. I recently had to replace the entire housing unit for the bottom rear lights. All of the lights are working properly except the one that is in question. This is a left rear position light. Any suggestions?
Dec 9, 2009 at 4:21 AM
JIS001
  • 3,412 POSTS
Check your fuses in the Rear Electronic Module located in the left rear cargo compartment.
Dec 10, 2009 at 6:13 PM
