2000 Volvo V70 Car ignition problem recognizing stage
256,000 MILES • 6 CYL • 2WD • AUTOMATIC
JD61082
My car keys wouldn't release from the ignition (side of the steering wheel in this model). I finally got the key out, however, I opened the door and the beeping started (it thinks that the key is still in the ignition). What is the problem and how do I fix it? Thank you!
Apr 3, 2009 at 12:14 PM
JIS001
  • 3,412 POSTS
Most likely cause is your steering column lock (Ignition switch tumbler)
Apr 6, 2009 at 5:52 PM
