1998 Volvo V70 Turbo
PATTHERAT
Engine Mechanical problem
1998 Volvo V70 All Wheel Drive
Bought a used 1998 volvo v70xc and am trying to replace the turbo. Am experienced in automotive but not with volvo. Need instructions to remove and replace turbo.
Aug 11, 2010 at 10:59 AM
JIS001
  • 3,412 POSTS
You need to remove the fresh air tube for the air cleaner, the feed pipe for the turbo, the 2 17mm banjo bolts for the coolant and the 17mm banjo bolt for the oil, the 3 13mm nuts for the cat to turbo and 4 13mm nuts attaching the turbo to the exhaust manifold.
Aug 28, 2010 at 7:09 PM
