1998 Volvo V70 Please Help :)
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
PUREISPOOR
This winter my car's battery died one cold night and the car wouldn't start. I got a jump and took it home and it ran fine for a few weeks. Then the service light started to come on and the battery died again. So i ordered the kit from CarMD.com to see if the computer could tell me what was wrong. The car's computer did not send a code to the CarMD unit so i was back where i started. Then the battery died completely so i bought a new battery thinking that the battery was too old. ( i recently purchased the car)
so i put in the new battery and it worked for about a week, then i was about to leave work and the battery had died again. I work at uhaul and we have some battery chargers for the trucks, i left the charger on the battery overnight so i could at least drive it home. the charger had a green light (it's a new battery it should be fine) but when i turned the key the electricals went out immediately.
i don't know what to do, i don't make much money and i am still paying for the car. please help me and make my life a little easier :p
thank you
Feb 4, 2009 at 3:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
First thing to check is the terminals and cables. Make sure the battery cables are tightened securely and also ensure terminals are free of any corrosion. If all is OK here, get the alternator tested. Most part stores such as AutoZone will test your alternator for free, on or off of vehicle. If your engine light is still on, the can pull the codes for that as well.
Let me know the results and I will follow up.
Thanks for using 2CarPros.com!
Feb 4, 2009 at 12:22 PM
