1998 Volvo V70 acceleration
300,000 MILES • 4 CYL • 2WD • AUTOMATIC
COACH K
my car starts fine and runs however when I try to accelerate it acually slows when idling if I try to rev up the engine it seems to "bog" down I can go 50 to 65 mph only after a long period of slow acceleration
Jan 10, 2010 at 12:47 AM
  • 75,988 POSTS
Check and test the following below:
Oygen Sensor
Catalytic Converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Note:If it doesn't apply,disregard.
Jan 10, 2010 at 12:08 PM
