2005 Volvo V50 Check Engine
72,000 MILES • 4 CYL • FWD • AUTOMATIC
INGEBRETT
Above Car's message came up, squeaky car noise.
What could be the problem? If more than one, please list.
Jun 4, 2010 at 2:24 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I am not that sure what you are after here, do you have a engine check light on? and do you have a noise that you are concerned about? if so some more information if you can, some indication as to when you hear it and if you feel it is suspension, engine or drive line will also help.
Mark (mhpautos)
Jun 4, 2010 at 2:42 PM
JIS001
  • 3,412 POSTS
No such message ever appears on the cluster like this unless you are being sarcastic about it? But if you do have a minor squeek while going over bumps or urning, then your front strut bumps are binding up causing it to make noise. You would need to remove the strut to replace. At this point, check to see if one or both of your front struts are leaking. If they are, replace them as well.
Jun 5, 2010 at 1:50 PM
