2005 Volvo V50 bushings
05V50
Suspension problem
2005 Volvo V50 Front Wheel Drive Automatic 31000 miles
are the bushings on the lower control arm filled with any type of fluid??It appears to be leaking. My 06 mini cooper has oil filled motor mounts.I'm wondering if this control arm bushings are the same???? Is the bushing towards the rear on the passenger side.thank you.
Dec 3, 2008 at 3:16 PM
  • 31,937 POSTS
Hi there,
I can only find a reference to a Polly urethane bush, you may have to contact Volvo spares to get a defining answer to this.
Mark (mhpautos)
Dec 3, 2008 at 6:57 PM
JIS001
  • 3,412 POSTS
No they are not filled with any type of fluid. I would look at your engine mount in front of the engine (right side) Those always leak and bust open.
Apr 3, 2009 at 2:31 PM
