V40 brakes
1940 VOLVO V40
BR2LE
I have a 2000 V40 with 109000 miles. Lately I noticed that when I back out of the garage and stop to shift from reverse to drive the brakes are not stopping the car as normal (slip). This is only if the car set for a couple of hours. I drive a mile and stop for the trafic light the brakes work nornal. Any suggesions?
Thanks,
A great Volvo lover
Nov 19, 2007 at 3:47 AM
MERLIN2021
  • 17,250 POSTS
When the car has sat for a few hours before you drive it open the hood, take the cap off the master cylinder, and have someone step on the brake gently, then release the brakes, do you see any turbulence an the master, if not the compensating port coul be sludging up a bit. Getting your fluid changed could help...A 2000 with this high mileage may need a few hydraulic parts by now!
Nov 19, 2007 at 6:13 AM
