Misfire code, loss of power on acelleration, shudders
LEESARAIN
Volvo V40 2000 with 97K miles. Going on a trip, car trouble literally five miles from entrance to Glacier National Park after driving ten hours over two days. Car drove well until I was passing a 60mph car I tried to acellerate to 75 and the car shuddered heavily, misfired, check engine light flashes. I pulled over. let car rest, then turned around to find garage on a Sunday. Local small mechanic checked and cleared codes. Misfire cylinder two. He checked the air filter (dirty - looks like mouse shredded something), checked spark plugs, looked clean except for cylinder two which was slightly brown, but he said fine. Checked spark plug gap, was correct. He said it could be bad gas. PUt in a bottle of Heet. Drove car to park and on Going to the Sun Road, a 25mph winding steep road to 6500 ft elevation. Car was ok at slow speeds. Next day, Monday, drove to European mechanic one hour away. Checked code. Misfire cylinder 2 again. He replaced spark plugs. He suggested may be coil, did not have in stock. HE test drove. Said car was fine at 100mph (!!). "Blew it out". Meaning going fast to clean out the fuel system? Said felt like fuel problem not coil. Added bottle of Techron. Left and continued on my trip, drove a few hundred miles, slowly and without accelerating fast. When pressing hard on gas pedal, car will misfire, shudder, go slow, flash check engine light. But able to go at slow even speeds, gradual acelleration to 50-60 mph, keeping rpms at 2000-3000, and downhill just fine. Manage to limp through the week like that. Problem still there, learn how to avoid the misfire. Next monday. On trip home. Stop at another mechanic. (tried to go to volvo dealer, they are too busy) This mechanic checks codes. Misfire cylinder two. Checks pressure. Slightly low, but OK. Notes that last mechanic put in wrong plugs, should have been "platinum". Suggests coil, coil wire or fuel injector. Switches coils to try and isolate problem. Says if the code returns as misfire cylinder two then the problem is probably a fuel injector. If it says misfire cylinder one, then it is the coil or wire. I drive 20 miles and try to get check engine light to go on after his reset, will not go on. SO he suggests I continue on my trip and have next mechanic check the codes and continue the diagnostic. Drive home slowly, car acts OK. Last 50 miles try acellerating, no misfire. INteresting. By the way, I filled up with Premium. So I am home now and will take it to local european auto mechanic. Apparently these symptoms are hard to diagnose. What do you think it is? Plugs, wire, coil, bad gas, fuel injector, fuel filter, catalytic converter, fuel pump, or???
Aug 8, 2006 at 1:04 PM
KARPINUK
Don't worry. Now U r OK. I had very similar Prob. When I inquired to Local dealer for price of coil he asked me which cylinder Nr. coil I want ? It gave me a click clue, the Company might have slightly different values set in different coils for each cylinders- lookwise all are same!
I swoped the coil on my own and it worked nice.
I can see that many mechanics don't know about this and when they clean the plugs, they swop the coils by mistake and hence the Misfire continues thereonwards.
Double check my assumption with dealer or some one knowledgeable before going further with me.
I would appreciate anybodu can confirm about different values set for different cylinder's coil - which I strongly believe.
Karpio
May 9, 2008 at 5:34 PM
FAITH SIBANDA
I had the same problem, replaced coils that were indeed cracked and old, cleared CEL error, and the car was fine or a day, next day had the same problem in the more, removed the MAF sensor, and cleaned it, put it back, error cleared on after that and car has been fine so far.
Apr 20, 2017 at 7:57 PM
KHLOW2008
  • 41,812 POSTS
All cylinder coils are the same value. They can be interchanged and normally I would mark them for reference if I am swapping them around. Sometimes the coils are not bad, just that the connections could be loose or contacts bad and moving them around resolved the problem.
Apr 24, 2017 at 1:44 AM
