1998 Volvo S90 brake noise
1998 VOLVO S90
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRIAN OVER
my volvo's front brakes make a creaking or snapping noise most of the time when i depress the brake pedal. the noise comes from both sides. I had it serviced and inspected at a volvo dealership. They could not duplicate the problem. the brakes and rotors are relatively new. it stops fine although the noise is annoying. I bled all the brake lines over the summer. this had no effect. thank you in advance
Jan 17, 2010 at 9:18 AM
DOCFIXIT
  • 18,828 POSTS
Could be suspension components like control arm bushings, ball joint,struts and mounts. hear any noise going over bumps? do it in REV when braking?
Jan 21, 2010 at 3:39 AM
