Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volvo
S80
Suspension
Lower Control Arm
Bushings
noise when making sharp turns
VOLVO S80
MO6TER
MEMBER
Why is my volvo making rubbing noise when I make sharp turns? Does this have anything to do with my Volvo Control Arm Bushings? Thank you
Oct 20, 2007 at 9:37 AM
ERIC CRAIG
MEMBER
I know for a fact that my control arm bushings need to be replaced, but they make noise every time I go over the smallest bump. Not while turning.
I was having a similar problem when I turned the wheel all the way, left or right. I believe the mechanic said I needed to replace my bump stops.
I'm not saying that your control arm bushings aren't worn out, just sharing what has happened to me with my 2004 Volvo S80.
Good Luck
May 2, 2008 at 3:31 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
