Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volvo
S80
Warning Lights
Check Engine Light
2005 Volvo S80 high rail pressure
2005 VOLVO S80
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
YVONNE ARKLESS
MEMBER
engine management comes on restricts performance also stalls can you answer why this is happening
May 8, 2009 at 9:31 PM
Experienced Mechanic
Pull the code/s from the computer this is your starting point to find out what's wrong with the engine management system
May 8, 2009 at 10:55 PM
YVONNE ARKLESS
MEMBER
have pulled code comes up high fuel pressure fuel pump ok injecters ok
May 9, 2009 at 2:49 AM
JIS001
Could you give me the exact trouble code that was scanned? Either the PO code or ECM code number?
May 9, 2009 at 3:56 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
