2005 Volvo S80
ABDUL-SALAM
Brakes problem
2005 Volvo S80 4 cyl Two Wheel Drive Automatic
how do i ajust my hand brake
Feb 20, 2010 at 2:45 AM
JIS001
  • 3,412 POSTS
Remove the cover right under the hand brake lever. Once you remove it you will see another cover which you just tilt up. Set the hand brake down and turn the 10mm nut clockwise totighten cable or counter clockwise to losen it. Turn it a few times and raise up the handle until you get it where you want it to be. Hope information helps you.
Feb 21, 2010 at 2:09 PM
