2003 Volvo S80 My Car smells like it is burning oil
JUDYBURN44
Smells problem
2003 Volvo S80 140000 miles
When I drive, my car smells like it is burning oil
When I turn my engine off, there is a clicking sound under the hood.
My driver side visor doesn't stay up - I am using a bungee cord to keep it up. Any suggestions?
The piece that protects the undercarriage got loose and had to be removed. What is it called and how do I replace it.
THANKS!
Jun 27, 2010 at 2:17 AM
JIS001
  • 3,412 POSTS
For the burning oil smell check for an oil leak. For the clicking sound, there could be a solenoid acting up. If this is a turbo engine, then I would suspect the turbo control valve which is near the air filter housing is the culprit. For your sun visor, well you need to replace it. And the last item that cover is usually called the belly pan. You will need to buy a new one with new bolts if you dont have the old bolts?
Jun 27, 2010 at 7:54 PM
