2003 Volvo S80 gas fumes from fuel pump area
2003 VOLVO S80
62,877 MILES • 6 CYL • FWD • AUTOMATIC
TERRY HARMS
how do I get to the fuel pump if I have to replace it?
There are strong gas fumes coming from the rear of the car. A local Volvo dealer checked my Volvo and told me that the fumes were coming form the fuel pump and I have to replace the fuel pump, which is working great. Is it possible that a gasket or O-ring is bad?
Oct 21, 2009 at 7:47 AM
MATHIASO
  • 1,209 POSTS
Disconnect the negative battery cable. Remove protective cap from the valve on the fuel rail. Connect a hose to adapter 999-5484 and place the other end in a clean container. Connect the adapter in the locked or closed position to the valve on the fuel rail. Unlock or open the adapter valve. After the fuel system pressure is relieved, remove the adapter and hose and replace the protective cap.
https://images.2carpros.com/forum/automotive_pictures/46384_fuel_1.jpg
Removal & Installation Before servicing the vehicle, refer to the Precautions Section. Relieve the fuel system pressure. Remove or disconnect the following: Fuel tank Fuel pump connector Large plastic fitting nut using special tool 999-7093 Fuel pump
https://images.2carpros.com/forum/automotive_pictures/46384_fuel_pump1_1.jpg
Use a new seal when installing the fuel pump retaining , the fumes may come from there.
https://images.2carpros.com/forum/automotive_pictures/46384_fuel_pump2_1.jpg
ask auto parts store for tool needed to remove fuel pump.you will be provided.
Oct 21, 2009 at 8:41 AM
