2001 Volvo S80 T6 Turbo Bearing hum /bearing replacement
2001 VOLVO S80
RUCK6
Drive Train Axles Bearings problem
2001 Volvo S80 Two Wheel Drive Automatic 110000 miles
How to replace front wheel bearings and determine which bearing is actually "humming"/needing replacement
Sep 15, 2009 at 9:06 AM
JIS001
  • 3,412 POSTS
hile driving swirve left and right. You should hear the noise go away on one side depending on where you take the load off. Once you figured what side it is, raise vehicle and spin the wheels. You shoul hear the bad bearing.
Sep 20, 2009 at 10:29 AM
