2001 Volvo S80 p0305, p0300
167,834 MILES • 6 CYL • 2WD • AUTOMATIC
ALMONDJOYTOY1
runs rough, check engine light flashes and there is a carbon/suet like smell from the exhaust. i changed the plugs and still no good
May 26, 2010 at 3:57 PM
  • 31,937 POSTS
P0305 Cylinder 5 Misfire Detected
Hi there the P0300 is also a miss fire code, i would be checking leads, vacuum leaks, coil, faulty injector No % cylinder will be the main problem, a comp check would not hurt either.
mark (mhpautos)
May 26, 2010 at 4:25 PM
JIS001
  • 3,412 POSTS
Ignition coils always seem to fail on these cars. While running pull coil up slightly. You should hear it popping indicating it is firing. If you do not hear it popping then coil is no good. You should be carefull or you could get shocked and it hurts a lot :o
Another way you can check it is if you have a code reader. Swapp coil #5 and #4 reset the light and drive it. If the misfire goes to #4 and you get a PO304 then you know the coil is bad. Good luck and let me know what happens.
May 27, 2010 at 5:24 PM
