2001 Volvo S80
97,580 MILES • 6 CYL • FWD • AUTOMATIC
MILLER AUTO CARE CENTER
how do i know what position to put the intake and
exhaust camshaft in before i put on the gears
thanks very much . frank from jamaica.
Aug 26, 2010 at 11:02 AM
how do i know what position to put the intake and exhaust cam before i put on both cam gears thanks very much for the answer frank from jamaica.
Aug 26, 2010 at 11:15 AM
JIS001
  • 3,412 POSTS
You need the special tool that locks the cams in the position they need to be in to install the cvvt hub and set the timin. Without that tool you will damage the valves if you do not set the timing right.
Aug 26, 2010 at 7:19 PM
