2000 Volvo S80 wrong spark plug installation
2000 VOLVO S80
ORAADMIN
Engine problem
2000 Volvo S80 V6 Front Wheel Drive Automatic 80000 miles
The spark plug I installed was too long and it is damaged, The car is volvo S80 year 2000 and it is 2.9 litre V6 , what it could have damaged.
Dec 8, 2007 at 3:21 PM
  • 31,937 POSTS
Hi there, was the plug to long? or the incorrect heat range? if to long, it may have fouled a valve depending on the configuration of the combustion chamber. or struck the piston. Is the plug broken? there may be bits of ceramic insulator in the cylinder, you may have damaged a valve or at worst cracked a piston. Do a compression test to check valves, and ask you mechanic if they have a borescope to view into the cylinder ans inspect for any damage,
mark (mhpautos) :D
Dec 8, 2007 at 3:53 PM
