Turn signals and Hi beam stopped working
HAROLD.BUNGER
Electrical problem 6 cyl Two Wheel Drive Automatic 60000 miles
Turn signals and Hi beam stopped working at the same time. All plastic fuses are good.
Mar 11, 2010 at 12:19 AM
JIS001
  • 3,412 POSTS
Where did you check fuses at? The engine compartment or inside the car?
Mar 14, 2010 at 11:38 AM
HBUNGER
I found the answer. Pull out the # 21, 22 and 23 fuses from the fuse box inside the passenger compartment. Turn the key until the accessories come on. There is no need to start the car, you just want the electronics to come on. Wait about 5 seconds. Turn the key off. Put the fuses back in and the problem is solved.
If someone tells you that you have to disconnect the battery, it is not necessary. Turning the key drains the capacators. That resets the malfunctioning modules.
Mar 14, 2010 at 12:42 PM
JGLECHTER
Just wanted to let you know I just had the same problem and I fix it in 5 minutes. Thanks for the assistance.
Apr 13, 2012 at 5:05 PM
JP RYDING
I registered just to say that the fuse pull fix worked for me just now. Was about 50ks from home so would have had a real issue. Thanks Hbunger!
May 30, 2017 at 1:40 AM
  • 55,511 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
Jun 1, 2017 at 4:58 AM
