2000 Volvo S80 Transmission Fluid Change
106,338 MILES • 6 CYL • FWD • AUTOMATIC
FATBOISMOKIE
I can't seem to find the drain plug for my transmission. Talked to the people at Kragen and they said i need 3.2 quarts of automatice transmission fluid, but I don't think that is right. Can you please tell me how many quarts of ATF i need?
And a step by step on changing the transmission fluid. [img:58d32441f1]http://www.2carpros.com/forum/automotive_pictures/146466_guns_1.jpg[/img:58d32441f1]
Jan 21, 2008 at 6:07 AM
JULAUS1
had same trouble you spoke of, so i drained my trans into large pan and measure it into a gallon jug. the best i can estimate i put in 7 quarts with a filter change. i would probably put in six quarts and then crank the engine and see how close this is. I can't seem to find the drain plug for my transmission. Talked to the people at Kragen and they said i need 3.2 quarts of automatice transmission fluid, but I don't think that is right. Can you please tell me how many quarts of ATF i need? And a step by step on changing the transmission fluid.
https://images.2carpros.com/forum/automotive_pictures/146466_guns_1.jpg
[/quote]
Feb 1, 2008 at 12:40 PM
JULAUS1
to change remove the belly pan.there are i think 10 or 12 bolts holding the trans pan on. be prepared to get oily. drain into large pan be careful when removing filter there is a large oil ring that can come off the filter and stay stuck in the hole that the filter goes in . make sure to remove out of this area. new filter comes with oil ring I can't seem to find the drain plug for my transmission. Talked to the people at Kragen and they said i need 3.2 quarts of automatice transmission fluid, but I don't think that is right. Can you please tell me how many quarts of ATF i need? And a step by step on changing the transmission fluid.
[/quote]
Feb 1, 2008 at 12:45 PM
