2000 Volvo S80 NO POWER
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
MCIVER
MY WIFE WAS DRIVING DOWN THE ROAD AN THE CAR JUST TURN OFF NO HEADLIGHTS NO HORN NO DASH POWER,THE RADIO WILL COME ON AN THE LIGHT ON THE DOOR.AN WHEN YOU TURN THE KEY YOU GET NOTHING.
Nov 4, 2008 at 9:04 AM
  • 75,988 POSTS
Get the battery and alternator load tested-could be the alternator not putting out or the battery is not taking the charge-also check all the fusible links
Nov 4, 2008 at 9:34 AM
MCIVER
already have put a new battery and the alternator is good. and also put a key ingitionand checked all the fuses that i could check.
Nov 4, 2008 at 10:16 AM
  • 75,988 POSTS
Check fuses 60amp A2/A7/A4 in the engine compartment fuse/relay box
https://images.2carpros.com/forum/automotive_pictures/12900_fuses_3.jpg
Nov 4, 2008 at 12:29 PM
