2000 Volvo S80 lost turn signals operation and no radio con
105,342 MILES • 6 CYL • FWD • AUTOMATIC
OWENS4433
I step into my car , it start like usual but I notice my signal indicator left and right will not work, also anything on the steering colum does not operate. Like curse, radio station control, and volume control. I did check out the fuse and relay everything check out good at this point I am lost as to what the problem maybe .
Dwayne O
Sep 29, 2010 at 11:33 AM
JIS001
  • 3,412 POSTS
I would recommend you take it in to the dealership for proper diagnosis since it seems you could be having an issue with the network cable? You could have a faulty contact reel, faulty steering wheel module or a bad central electronic module?
Sep 29, 2010 at 4:46 PM
OWENS4433
[quote:30ed205c9c="JIS001"]I would recommend you take it in to the dealership for proper diagnosis since it seems you could be having an issue with the network cable? You could have a faulty contact reel, faulty steering wheel module or a bad central electronic module?[/quote:30ed205c9c]
Sep 30, 2010 at 6:05 AM
BMRFIXIT
  • 19,053 POSTS
Have to check for codes
if all fuses OK
with engine running do you have an air bag light on too
suspect a faulty wire or cable
Volvo is capable of self diagnose just need the correct tool to access the codes
most common place for a wire failure is in the wheel
Oct 1, 2010 at 11:25 PM
BMRFIXIT
  • 19,053 POSTS
Thank You !!
Check engine light on ,an OBDII reader should be able to get you the codes no special Volvo tools need
let me know as they maybe related
Oct 2, 2010 at 11:36 AM
