2000 Volvo S80 idiot lights
127,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVEN H
I replaced the alt. and since the air bag syst. restraint light will not turn off. I now have a traction control / ABS light that is on and at idle the low oil pressure light says no pressure turn off ensine asap but oil is full. As soon as you raise the rpm it goes off
Nov 17, 2008 at 9:12 AM
  • 31,937 POSTS
Hi there,
you may have a faulty oil pressure sensor, have the pressure tested with a mechanical gauge, if OK replace the sensor, as for the other codes do a scan and a code clear and re test systems.
Mark (mhpautos)
Nov 17, 2008 at 8:29 PM
