2000 Volvo S80 dooor
2000 VOLVO S80
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEVO0084
my left rear door will not unlock are open from the inside.
Apr 12, 2010 at 8:15 PM
JIS001
  • 3,412 POSTS
If it does not unlock then most likely the door lock assembly would need to be be replace. As for the door not opening from theinside, check to see if the child safety lock is on. If it is off, whn you remove the door panel to to replace the lock assembly, make sure the cable is not damaged and check to see it did not seprate from the hande. If it did, make sure the handle is not damaged. If it is, then I believe the whole door panel would need to be replaced?
Apr 13, 2010 at 2:59 PM
