2000 Volvo S80 desiel in a vovlo premium engine
131,999 MILES • 6 CYL • FWD • AUTOMATIC
MBODHIAMBO
Can desiel be remove from my car engine?
Oct 5, 2010 at 11:12 AM
JIS001
  • 3,412 POSTS
Do you mean you put diesel in a gasoline engine? What you need to do to pump it out is get a fuel pressure gage. Remove the gage part. Jump the fuel pump relay with the key on engine off. Let the fuel pump run so that it pumps out the diesel. Then add some gasoline and do the same to flush it out.
Oct 5, 2010 at 4:58 PM
