2000 Volvo S80
2000 VOLVO S80
160,000 MILES • 6 CYL • FWD • AUTOMATIC
RICH HARDING
my transmission when codes p0751 & code p1618< i dont know what this is> are present will move but feels like it slips when i clear these codes the car drives right good strong shift points & performance till the codes show again ,,,,please help
Apr 26, 2008 at 12:07 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
P1618= Serial Peripheral Interface PCM Interprocessor Communication Error
you havent by anychance had any transmission work done on it have you?
You may have a bad gear shift selector switch, which is a fairly common problem. or a damaged ECU wiring harness or bad ECU which is very hard to find usually!
for the p0751 code you are best off having a trans shop look at your shift solenoids, they could be faulty due to the p1618 code or they could be causing it.
Apr 26, 2008 at 4:27 PM
