1999 Volvo S80 starting
MBCHADWELL
1999 Volvo S80
car will not start it tries to turn over and you can hear the fuel system kicking in but will not start and is not giving a message in the message center
Dec 5, 2009 at 12:00 PM
  • 75,988 POSTS
Do below might lead you somewhere
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
_________________
Dec 5, 2009 at 8:13 PM
