1999 Volvo S80 Driveside power window motor / regulartor re
1999 VOLVO S80
150 MILES • 6 CYL • FWD • AUTOMATIC
CPONCESR
Without removing the window regulator I managed to remove the motor. On installation I am having trouble lining up the mount bolts and the spline to the regulator. Any help would be appreciated.
May 15, 2010 at 8:48 AM
JIS001
  • 3,412 POSTS
The window motor comes with the regulator as an assembly.
May 16, 2010 at 3:19 PM
CPONCESR
That's understood, that was not my question. But Thanks anyway...
May 18, 2010 at 2:14 AM
JIS001
  • 3,412 POSTS
The only other thing you can try doing is removing the regulator itself and aligning the motor on the outside and then reinstalling. When you get the motor in, you will need to reinitialize the auto up function.
May 19, 2010 at 2:15 AM
CPONCESR
Thank you, that was helpful, I will give it a try.
May 19, 2010 at 1:06 PM
