2000 Volvo S70 veriable valve timeing
TRAVIS2610
2000 Volvo S70 Two Wheel Drive Automatic 165000 miles
i had to take the veriable timing gear off to replace the cam seal now the cam moved where do i align the marks back up
Aug 15, 2009 at 9:17 AM
JIS001
  • 3,412 POSTS
You need a special tool to lock the cams and then install the vvt hub but to set it up is very complicated and I would recommend you tow your car to a shop or the dealership to have it set up properly if you are not familiar with how VVT works or you dont have the tools. The tool set I have looked around can cost between $700 - $900?
Aug 16, 2009 at 8:45 AM
