2000 Volvo S70 Intermittent A/C issue
OLDGUY28613
Air Conditioning problem
2000 Volvo S70 Front Wheel Drive Automatic 154500 miles
My A/C has an intermittent fault -- the fan keeps blowing, but the cooling stops. I've not detected a certain cause, but it happens in traffic, on the interstate, and sometimes if I start or stop quickly or gun it to accelerate. My mechanic says the coolant is to spec, but it didn't happen during the day he had it.
Turning off the A/C switch on the dash for a few minutes will -sometimes- cause the cooling to start again when I re-engage it.
Any ideas? This is one of the 2000 S70s that has continual electrical shorting issues -- tail lamps going out, etc. Could that be involved?
May 31, 2008 at 12:37 PM
MASTERTECHTIM
  • 4,750 POSTS
does the cooling fan run when the ac is on? were the pressure readings good?
May 31, 2008 at 12:45 PM
OLDGUY28613
Fan runs (on auto and on manual). The pressures were normal, according to the mech.
May 31, 2008 at 1:06 PM
MASTERTECHTIM
  • 4,750 POSTS
he is missing something. do you notice when its not working is the ac compressor coming on? possible loose connection near ac compressor
May 31, 2008 at 1:11 PM
OLDGUY28613
I'll check that this week -- I'm on the road, won't be able to get it back to him until Thursday....
May 31, 2008 at 1:19 PM
