1998 Volvo S70 no cool air or warm heat
111,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHARPE
I have changed the climate control,temostat and the temp sensor and flushed the heater core and still cant figure out the problem
Oct 26, 2010 at 8:41 AM
JIS001
  • 3,412 POSTS
NOTE : A new control module must always be programmed for left or right-hand drive before it will work. Damper motors, etc cannot be self-adjusted until programming is complete.
If a used control module is fitted programming for left or right-hand drive must be checked to ensure that it corresponds to the car
New control modules are set up for petrol engines with no dust filter. Re-program these parameters if they do not correspond to those of the car into which it is being fitted.
Before the control module is programmed the two green indicating diodes will flash. If the A/C is off and recirculation is selected the indicating diodes remain lit.
Oct 26, 2010 at 4:56 PM
