2000 Volvo S70 Changin Trans Fluid - fixing the effects
2000 VOLVO S70
125,000 MILES • 6 CYL • FWD • AUTOMATIC
VYTAS333
Hi Guys!
I have a used 2000 Volvo S70 with the 2.4L 5 cyl and 5-speed auto trans. When I got it I thought I would catch up on the maintenance, and had a transmission shop replace some leaky seals and replace the transmission fluid. Immediately afterward, the car had no third gear. Since I only paid $39.95 for the fluid change, I would guess they used generic rather than Volvo specific synthetic AT fluid. Now they're quoting me over $2K to replace the trans.
My question - would flushing and putting the right fluid in make sense, or am I already kaput? They said the detergents in the new fluid probably unstuck the gunked-up hydraulics, and that's why it fails in third now. Odd that it would happen immediately, so I'm looking for your wisdom to avoid a $2-3K repair bill on a well-used car. Thanks for your thoughtful reply.
Vocal in Virginia
Sep 23, 2008 at 2:14 PM
2CARPRO JACK
  • 11,533 POSTS
The only way a flush would help is if they used a machine and replaced the entire capacity of the trans. The damage may already be done.If they used the wrong fluid I would have a nice sit down with the shop manager and see what you can work out. Also might not hurt to have a shop that does Volvos take a look at it and see what they can come up with
Sep 24, 2008 at 12:52 AM
