1999 Volvo S70 RACKINPINON REMOval
1999 VOLVO S70
SSKATELL
Steering problem
1999 Volvo S70 4 cyl Front Wheel Drive Automatic
I need to remove rack. Please help witjh aNY DIAGRAMS. qUICK TIPS ETC
Apr 29, 2009 at 2:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Separate the steering gear from the steering column by lifting the floor carpet below the steering column and remove the pinion shaft bolt.
Remove or disconnect the following:
Right front wheel
Lower ball joints
Center cross member
Front exhaust pipe
Rear engine mount
Heat deflector plate
Steering gear left mounting bracket
Power steering hoses
Steering gear right mounting bracket
Slide the steering gear housing to the right and lower the assembly to remove.
Let me know if you need further assistance..
Thanks for using 2CarPros.com!
Apr 29, 2009 at 5:46 PM
