1999 Volvo S70 low oil pressure
125,000 MILES • 6 CYL • FWD • AUTOMATIC
EDGAR BRUNO
i change all d lifters in d head because there was taping coming from d tap of head it went away but it came back now therer is a low oilpressure and d taping is back no oil ligth is on but oilpressue is not what it sould be??????
Apr 19, 2010 at 3:46 PM
  • 75,988 POSTS
Could be the oil pump failing check the oil pressure with a mechanical gauge.
Apr 19, 2010 at 10:08 PM
JIS001
  • 3,412 POSTS
Your oil pick up tube seals are leaking. You would need to remove the oil pan and replace the seals from the screen and the tube inside the oil pan that is held by a 10mm bolt. Clean pan up really good and get the chmical gasket from Volvo to aply on the pan to reassemble. You will also need to order the oil cooler seals as well since you will need to remove it to drop the pan.
Apr 20, 2010 at 3:13 PM
