1998 Volvo S70 starter replacement
JOENAPOLI
1998 Volvo S70 Two Wheel Drive Automatic 130000 miles
Hello and thank you for your time.
I need to know the best way to access the starter for replacement.
#1) Is it through the top having to remove the intake.
#2) From the front by having to remove the radator and every thing in front of it.
#3) or from under neight the bottom of the car.
Once I have access to the starter its a no brainer from there. Thanks in advance for you reply. Joe
Sep 13, 2009 at 4:45 AM
JIS001
  • 3,412 POSTS
Is this a turbo or none turbo engine.
Sep 13, 2009 at 9:08 AM
JOENAPOLI
it is a non turbo
Sep 13, 2009 at 2:27 PM
JIS001
  • 3,412 POSTS
You would need to remove the fan shroud to access the starter.
Sep 14, 2009 at 3:40 PM
