1998 Volvo S70 fuel filter/pump
140,000 MILES • 6 CYL • AWD • AUTOMATIC
MARIAC3
engine sputters and then stalls....is it fuel filter?
May 6, 2009 at 1:42 AM
JIS001
  • 3,412 POSTS
Disconnect the mass air flow sensor. If your vehicle runs ok after that then you have a faulty mass air flow sensor. Also if you want to know about fuel pressure you will need to hook up a fuel gage and see what the pressure is.
May 10, 2009 at 5:24 PM
