Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volvo
S70
Suspension
Ball Joint
1998 Volvo S70 BALL JOINT
1998 VOLVO S70
139,000 MILES • 4 CYL • AWD • AUTOMATIC
RISHARRI12
MEMBER
1 POST
What kind of ball joint does a s70 t5 have 2 bolt or 4 bolt
Apr 2, 2010 at 11:00 AM
JIS001
Experienced Mechanic
You mean the lower ball joint? That is pressed in to the control arm. You may need to replace the whole control arm if you can not get it separate.
Apr 5, 2010 at 5:21 PM
Add image or video
Ask a new question
Check engine light
Engine won't start
