1998 Volvo S70
137,078 MILES • 4 CYL • FWD • AUTOMATIC
WALLY1950
Every now and then when you come to a stop and start off it will start to sputter and cut off , then it is hard to crank ,the check engine light comes on code 3 PO455 SAYING EVAP SYSTEM LARGE LEAK, can't find any leaks at all , front or rear ! can you help ? Thank's Wally
Apr 12, 2010 at 6:30 AM
JIS001
  • 3,412 POSTS
You have 2 separate problems here. The evap large leak you would need to have the evap system smoke tested for leaks and also do a fuel pressure cap test to see where the major leak is at. As for the stalling out and hard start, you will need to have it diagnosed. You could have a bad mass air flow sensor?
Apr 12, 2010 at 2:16 PM
