Also I usually do my service with the dealer but as I said before sometimes it’s a bit difficult to find the time. How would I go about finding a reputable mechanic who works on foreign cars?
Any help would be greatly appreciated. Thanks
Measure front rotor thickness against the stamped discard limit and the higher brake-service minimum before machining or replacing them. Volvo rotors are soft and have little allowance, so expect replacement every brake job or every other job; do not turn them if that would drop them below the service limit. Ask locally for a reputable independent shop experienced with European cars.
The owner of a 2001 Volvo S60 with 38,000 miles had front pads replaced at 17,000 miles and was told Volvo rotors are not machined. A later shop recommended new front rotors, which seemed early, and the owner asked about expected rotor life and finding a reputable foreign-car mechanic. Experts said rotors should generally last at least two pad changes, but soft Volvo rotors may need replacement every job or every other job depending on driving. They explained that a service minimum is higher than the discard thickness, so turning can remove the remaining allowance and force another replacement.
